I have a 1998 Buick Regal that had a bad ignition switch, I thought.
(1998 Buick regal has no power to the fuse block for several circuits. heated mirror, cruise control, hvac and low blower circuits are all dead. Naturally, my cruise control, air conditioning system, and low beam headlights do not work.)
I replaced the ignition switch with one from a boneyard, and now the fuses that are dead are:
power drop
bcm
wiper
crank signal bcm cluster
heated mirror
steering wheel controls
Did I get the wrong ignition switch or is this one bad too? This one came with a white plunger this witha 2 wire connector on it. Not sure what it is for. My car has the shifter on the floor.
power drop
bcm
wiper
heated mirror
Aug 16, 2010 at 7:35 PM
