1997 Buick Regal Control Module Ignition
1997 BUICK REGAL
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
BILLJACKSON215
I recently had a belt shred and I replaced it. I got only about 1/2 mile and started to stall out. It seemed like i was out of gas but i had plenty . I thought mabe it could be Ignition Control Module or coil pack. Is this true ? Please Help !!!
Jan 15, 2008 at 5:09 PM
MASTERTECHTIM
  • 4,750 POSTS
your belt had to shred off for a reason. first id check all the pulleys, especially the alternator pulley. lets make sure its not a charging problem, next the belt most likely would have damaged the crank sensor not the module or coil. i hope this helps
Jan 15, 2008 at 5:22 PM
