1996 Buick Regal Torque specifications
1996 BUICK REGAL
DRICH1212
Engine Mechanical problem
1996 Buick Regal 6 cyl Two Wheel Drive Automatic
What is the torque specifications to the 1996 Buick Regal 3.1L engine, for the heads and the valves? Thanks in advance
Jul 12, 2008 at 9:51 AM
JDL
  • 16,098 POSTS
Go to www.autozone.com then click on (vehicle repair guides) follow the links, the information you need, should be there.
My information shows, you tighten all the head-bolts in the proper sequence to 33 flb. Then make a second pass, turn the bolts an addtional 1/4 turn or 90 degrees.
Jul 14, 2008 at 2:00 PM
