Bought the car used. Runs smooth. Noticed I had no horn when pressing the middle of steering wheel. Noticed the horn wires were not hooked up to the horns in the front of the car. When I hooked them up, they stay on. I checked the fuse and it isn't damaged, but since the horn works (and stays on) when hooked up, I didn't think it was a fuse causing it .Since there is an airbag in the steering wheel, I can't really take it apart to look inside there for a solution to the problem. Someone else suggested that I disconnect the negative battery cable, reconnect everything, and the problem should clear itself, but it there are any bent parts in the steering wheel center causing it, that wouldn't help. What can I do?
May 20, 2008 at 10:40 AM
