My driver's side door will not open when I put the car in park with the engine running and try to open the door even after I unlock the doors electrically or manually. It also will not open sometimes when the car is turned off and the doors unlock automaticly...the only way to open the door is to start the car again and put the window down and open it using the outside door handle and then not then until after trying several times lifting the door handle. Is there some kind of electrical sensor in the door that is not working? What is causing this and how can I fix its? Any help you can give me would be greatly appreciated...Thank you.
Nov 9, 2008 at 1:04 PM
