my low coolant light keeps blinking on and off but the car isn't running hot. what could cause this. there are no visible leaks anywhere.
Mar 9, 2009 at 9:44 PM
BLACKOP555
CERTIFIED EXPERT
make sure your coolant is full in the resevoir and in the radiator. if it is still going on and off, check to make sure the wire isnt shorting out for it, if that is good then the level sensor has failed and you need a new one!
Mar 9, 2009 at 10:22 PM
YASGER
MEMBER
[quote:069230ce28="a.foster2"]Engine Cooling problem
1995 Buick Regal 6 cyl Front Wheel Drive Automatic 78000 miles
my low coolant light keeps blinking on and off but the car isn't running hot. what could cause this. there are no visible leaks anywhere.[/quote:069230ce28]
