1995 Buick Regal BRAKE LIGHTS WON'T WORK
1995 BUICK REGAL
100,000 MILES • 6 CYL • FWD • AUTOMATIC
AFFORDABLEFIBERGLASS
MY BRAKE LIGHTS JUST DECIDED TO QUIT WORKING. I HAVE REPLACED THE BULBS, FUSES, REAR WIRING BRAKE HARNESS AND THE BRAKE SWITCH AND THEY STILL WON'T WORK. WHAT ELSE COULD IT BE? THEY CAME ON WHEN FIRST REPLACED EVERYTHING AND THEN ONLY 1 SIDE WORKED AND NOW NOTHING. EVERYTHING HAS BEEN REPLACED WHAT ELSE COULD IT BE?
Apr 15, 2009 at 11:01 AM
JDL
  • 16,098 POSTS
Hello, does the highmount brake lite work? The highmount is wired differently than the lower brake lites, the lower brake lites are wired through the turn signal switch. At the malfunctioning brake lite, did you check for B+ and ground?
Apr 15, 2009 at 11:13 AM
NO THE HIGH MOUNT BRAKE LIGHT DOES NOT WORK EITHER. ONE SIDE WORKS IF YOU USE THE TURN SIGNALS AND THEN FOR NO REASON THEY DON'T WORK. CHANGED BRAKE LIGHT SWITCH AND REAR WIRE HARNESS INCLUDING ALL TAIL LIGHTS. EVERYTHING WORKS BUT BRAKE LIGHTS AND HIGH MOUNT BRAKE LIGHT. ARGGGG
Apr 15, 2009 at 11:44 AM
JDL
  • 16,098 POSTS
Did you check the voltage circuits at the brake switch? The orange wire is feed to the switch, hot all the time. The white wire goes hot when the switch is activated, the white wire carries the feed for all the brake lites.
Apr 15, 2009 at 12:45 PM
NO DIDN'T CHECK THAT BUT PUT IN A NEW BRAKE SWITCH ALREADY WORKED FOR 1 DAY THEN 1 BRAKE LIGHT WORKED THEN NONE. WILL DOUBLE CHECK THOSE WIRES.
Apr 15, 2009 at 5:23 PM
