1995 Buick Regal ac clutch not engaging
1995 BUICK REGAL
108,532 MILES • 6 CYL • 2WD • AUTOMATIC
CHRISTEJ524
I have checked the freon and it is ok, I have checked the continuity of the clutch and it is ok where do I look next
Apr 17, 2010 at 10:49 AM
HMAC300
  • 48,601 POSTS
there is a cyclepressure switch located by the evaporator. It will have 2 wires going to it an dit's aorund switch. check there by jumping the wires to see if the clutch works. it should as long as the a/c is on. if you want apply poer to one side ofn the switch and see if it comes out the other side. If it does it should be good. then it might be a relay or the control switch.
Apr 17, 2010 at 6:27 PM
