1994 Buick Regal heater core
1994 BUICK REGAL
MR_FIXIT522000
Heater problem
1994 Buick Regal 6 cyl Front Wheel Drive Automatic
Im need to service the heater core,it leaks antifreeze. Could you please advise me on how to access it?
Jul 29, 2008 at 4:10 PM
MERLIN2021
  • 17,250 POSTS
Disconnect negative battery cable.
Remove air cleaner assembly.
Drain cooling system. On 3.1L, rotate engine forward on mounts as necessary. On all models, disconnect hoses from heater core. Remove right and left sound insulators from below instrument panel. Remove floor duct leading to rear compartment.
Remove cover and heater core. To install, reverse removal procedure.
Jul 29, 2008 at 4:57 PM
