1994 Buick Regal Cruise control doesn't work at all
1994 BUICK REGAL
75,000 MILES • 6 CYL • FWD • AUTOMATIC
TIMBO NEPAL 22
I broke off a "computer chip" key in the ignition of my 1994 Buick Regal Custom. I watched as the locksmith disassembled The steering column in order to get the key code necessary to make a new key.
I only just now noticed, eight months or so later, that my cruise control doesn't work at all, and I'm pretty sure it hasn't worked since that day, and I know that it worked prior to the locksmith's "intervention."
What do you think could be the problem???
Cordially, etc.
Mar 29, 2010 at 9:20 PM
BLUELIGHTNIN6
  • 16,542 POSTS
first may want to inspect the brake lights. if they are working then check fuses. when you try to turn on the cruise control, does the cruise indicator light come on at all in the instrument cluster ?
Mar 30, 2010 at 1:43 AM
TIMBO NEPAL 22
The fuses ate fine, the brake lights are fine and no, the indicator light does not light up.
Mar 30, 2010 at 10:52 AM
BLUELIGHTNIN6
  • 16,542 POSTS
seems like your cruise control switch is not operating than.. there could have been a wire connection knocked loose during the previous repair in the steering column.
Mar 30, 2010 at 2:24 PM
