1993 Buick Regal No Go
1993 BUICK REGAL
EAGLEUSN
  • 5 POSTS
Engine Performance problem
1993 Buick Regal 4 cyl Two Wheel Drive Automatic
I did a full tune up on my car and now it is acting ( no wanting to GO ) I followed the instructions on spark gap but the plug gap was at 0.80 instead of 0.45 like it said to set it at should I put them back to 0.80 or what else could cause the car to act like it has no fuel
Oct 18, 2009 at 4:37 PM
You sure this engine is a 4 cylinder ? Double check
Oct 18, 2009 at 4:42 PM
EAGLEUSN
  • 5 POSTS
Sorry I thought I changed it to 6 cyl my bad
Oct 18, 2009 at 4:57 PM
Now what liter is it? so I can get this rolling back to the road
Oct 18, 2009 at 4:59 PM
EAGLEUSN
  • 5 POSTS
It is a 3.1 multi port fuel injection
Oct 18, 2009 at 5:10 PM
Your sparkplug type should be R44LTSM and the plug gap should be .035 correct it and makes sure all connections are nice and firm/tight.
Be advised stay in this post go back and delete the other one
Oct 18, 2009 at 5:16 PM
EAGLEUSN
  • 5 POSTS
Ok I will try that I was going by what it said in the book that came with car and even at 0.45 it is still running WORSE then when it was at 0.80 what the other plugs were set at and i checked all connections they are all tight
Oct 18, 2009 at 5:21 PM
EAGLEUSN
  • 5 POSTS
wanting to make sure before do it again and why is it running worse now then when it was set at .80
Oct 18, 2009 at 5:48 PM
Did you wire the plugs wires correctly, wrong type of plugs will make the engine idle erractically whether its gap properly or not-
Did you gap it yet or what??
Oct 18, 2009 at 6:14 PM
