1993 Buick Regal gas tank
1993 BUICK REGAL
JDUMAINE
1993 Buick Regal 6 cyl Two Wheel Drive Automatic 265 km miles
I may have air in the gas tank. The fuel handle keeps shutting off. I have tried to pull the nozzle out a bit but doesn't help. Takes a long time to fuel
Apr 11, 2010 at 12:14 PM
There is a breather that runs from the tank to the filler tube. Check to make sure the it isn't damaged, bent, plugged... If it can't release the air as the tank fills, it will keep shuting the pump off because the fuel fills the filler tube and backfeeds into the pump nozzel.
Let me know what you find.
Apr 14, 2010 at 8:52 PM
