1991 Buick Regal cam position sensor
1991 BUICK REGAL
83,000 MILES • 6 CYL • FWD • AUTOMATIC
DAVE R
Computer code says problem with cam position sensor, I have changed sensor, checked wiring, replaced ign module, MAF sensor, still same code. If sensor was bad wouldn't it effect performance? Car runs fine, gets 23-25 mpg. Doesn't cam pos. sensor sequence the fuel injectors? Help please.
Jul 25, 2009 at 12:28 PM
JDL
  • 16,098 POSTS
Hello, maybe the magnet fell off the back of the cam gear? I believe the vehicle will run just fine without it, but, the injectors will probably revert to mfi, will not pulse sequentially.
If the magnet is still there, then you have another issue.
Jul 25, 2009 at 1:39 PM
