Problem - Car is running very rich, no smoke but strong order of fuel at tail pipe. Loss of power, car shakes at 40 mph or 1900 - 2000 rpm. It came on quickly.
Tested fuel pressure before rail (43) at fuel rail (38) and stays there while running. Checked idle control TPS both seem to be fine.
I have replaced the fuel pressure regulator, cleaned all injectors and replaced all seals, plan to change all plugs in the a.m.
Question is what else may cause such a problem as this? I don't think it is pump or filter related because of the pressure reading from the test.
Can you help with this one?
Mar 5, 2009 at 8:39 PM
