Won't hold a charge.
1987 BUICK REGAL
230 MILES • 6 CYL • 2WD • AUTOMATIC
WINN450
I replace the Alternator on this car 1 month ago. Eveything work fine until last week. It began giving symptom like the alternator is bad again... ticking sound when I tried to start the car. The car starts with not problem while getting a jump from another vehicle. However when I try to drive any distance it cuts off as if the battery is not staying charge. when I get a jump..it stats and run great for a while but again it seem the battery is not staying charge. Today I had the battery checked/charge and installed a new alternator. The car started and ran good. I cut it off for about an hour..went out and attempted to start it up...same problem. What else can this be? More info about the model of this vehicle..its a 3.8 liter Turbo fuel injected G/N
Mar 30, 2009 at 7:52 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:6d027681bc="winn450"]Electrical problem
1987 Buick Regal 6 cyl Two Wheel Drive Automatic 230 miles
I replace the Alternator on this car 1 month ago. Eveything work fine until last week. It began giving symptom like the alternator is bad again... ticking sound when I tried to start the car. The car starts with not problem while getting a jump from another vehicle. However when I try to drive any distance it cuts off as if the battery is not staying charge. when I get a jump..it stats and run great for a while but again it seem the battery is not staying charge. Today I had the battery checked/charge and installed a new alternator. The car started and ran good. I cut it off for about an hour..went out and attempted to start it up...same problem. What else can this be? More info about the model of this vehicle..its a 3.8 liter Turbo fuel injected G/N[/quote:6d027681bc]
You said you replaced Alternator ran it for a while and it done fine. Was that the only run you done with it? if so have you check to see if there is a draw on the battery. Check the link below for instruction on testing for a draw.
https://www.2carpros.com/first_things/why_is_my_car_battery_dead_over_night.htm
Mar 30, 2009 at 8:05 PM
HAWK16
I had this problem and it was the positive battery cable shorting out internally. Once I replaced it all good.
Apr 24, 2018 at 12:56 PM
