1983 Buick Regal carbuerator
1983 BUICK REGAL
93,000 MILES • 6 CYL • 2WD • AUTOMATIC
GSINGH89
my car stops sometimes and it bogs alot i sprayed carb choke ...but it continues ...it lags when i push gas
Aug 27, 2010 at 2:48 AM
Hesistating could be caused by the following:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking,fuel filter or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard and keep testing
Aug 27, 2010 at 4:21 AM
