THe harmonic balancer is located at the bottom of the front side of the engine. If you follow the accessory belts, it will be connected to the lowest pulley.
As far as the engine, honsetly, if it is locked up, most times it's not worth fixing. There are a few things that can cause it, broken connecting rod, broken crankshaft... As a result, it usually ends up cheaper to replace the engine because major damage has been done to the engine block. Plus, you would have to pay labor to have it repaired in addition to the parts.
See if you can get the harmonic balancer to turn and let me know what you find.
Mar 19, 2010 at 11:31 AM
