Interior problem
2006 Buick Ranier 6 cyl All Wheel Drive Automatic
Hi, The rear passanger door will not open from inside the vechile. It sounds like something either broke off or came loose inside the door . When you pull the door handle you can here something has come loose. My question is how do you remove the panel to get inside for repairs? I removed the two bolts from the arm rest but i'm afraid of breaking the tabs or something by trying to force out the panels. THANK YOU
Jan 14, 2010 at 10:59 AM
