I'm receiving error code P0410. I check all of the fuses connected with this circuit but am not sure how to tell if a relay is bad or if it is the pump itself. I reset the service engine light and that seemed to work for about a day and then it came back on again. Where should I start in fixing this problem and where can I get a schematic of the entire system so I know I am checking it all.
thank you
thank you
Mar 16, 2009 at 9:08 PM
