[quote:0bb7d25588="racefan966"]Ok looking over the wiring diagram I see that the rear doors have their own lock and unlock relay. So I would check the lock relay for the rear doors. It is located in the rear fuse block under the left (drivers side) rear seat. It is relay number 18. If you have a multi meter or test light you can check it. Simply back probe the gray wires that go the locks (the gray wires are the lock side) hit the lock on the switch and see if you get power. If you don't get power then the relay is bad just replace it and it should work again. Thanks and let me know how it goes.[/quote:0bb7d25588]
It was a bad connection on the gray wire. Probably wouldn't hace found it without your help. Thank You!
Oct 6, 2009 at 10:56 AM
