engine
BUICK PARK AVENUE
DEE1230
I have a 1998 bucik park ave with app 120,000 miles on it, i recently had a new transmission put in and since i got the car back i noticed that the rpm will drop below 1 and kind of seize the car for a second everytime i am staying still at a light or stop sign. I took it to mechanic and they noticed that when you take off the engine oil cap there is a vacumm effect which should not be happening, when you remove the cap the rpm drops on the car also, is this a vacumm leak, the mechanic was bewildered and had no answer? also the car is making a slight squeakign noise from underneath?
denise
Jul 28, 2007 at 5:30 PM
MERLIN2021
  • 17,250 POSTS
I'd say the only way for the vac issue is a hole in the intake manifold...
Aug 13, 2007 at 12:47 PM
