1998 Buick Park Avenue s belts
1998 BUICK PARK AVENUE
SANDRASWIM
Engine Mechanical problem
1998 Buick Park Avenue 6 cyl Front Wheel Drive Automatic
how do you replace the s belt if the motor mount is in the way
May 1, 2009 at 10:20 PM
2CARPRO JACK
  • 11,533 POSTS
Do you mean the drive belt? The bottom front bolt is actually a stud, remove the nut and the stud takes an inverted Torx socket to remove it from the block. Then the sleeve between the mount and block will come out and you can replace the belt
May 2, 2009 at 8:29 AM
