[quote:204ec27768="merhart"]Electrical problem
1998 Buick Park Avenue 6 cyl Front Wheel Drive Automatic 130000 miles
My right flasher doesn't work although my
right hazard and brake light works[/quote:204ec27768]
The BPAs do not use the old style inexpensive EL12 flasher unit. They use a dealer only flasher module part that costs around $50, but to install it you have to pull the entire dash to access it. Huge job! The unit is white plastic and about 3 inch by 1.5 inch and encloses a couple mini flasher units inside. If your emergency flashers work but one of the turn signals will no longer come on, you should probably start by checking to make sure all your turn signal bulbs on that side work. I'm assuming that yourbulbs are good as you said the hazard and brake lights all work. The next most likely part failure is the multi function turn signal lever losing the ability to carry the load of the turn signal and cornering lamp.
A simple test for this is to remove the light bulb from the cornering lamp (the bright light that illuminates the side that you are turning to, not the turn signal bulb). After removing the bulb, retest your turn signal. If, like mine, it resumes flashing, that would indicate that the turn signal lever can not handle the electrical load anymore and may need to be replaced. Or if you can live without the cornering lamp, you can postpone the repair til a later date. A more exact test is to test the resistance between the wires coming from connector C202 (multi funtion turn signal harness) and compare the left and right signals. I can't recall the exact pin to test right now. - bowfan
Feb 27, 2008 at 11:13 PM
