After a tire rotation, I had a low tire pressue warning that would not reset. Also, the next day my windshield wipers will not reset to the down position when I turn them off. THe wipers will go full down when I select the intermittent wipers speed.
I disconnected the battery to try to clear the faults. THe tire pressure fault did clear, the wiper position problem did not correct. Also, after disconnecting the battery, the fuel gauge pointer is on the wrong side of the stop peg and will not function or reset.
Any help you can provide will be appreciated.
Randy
Randy
Jun 7, 2008 at 12:24 PM
