1994 Buick Park Avenue Eninge redlines by itself
1994 BUICK PARK AVENUE
110,000 MILES • 6 CYL • FWD • AUTOMATIC
JEFFBRIGGS18
  • 6 POSTS
Hello, i have been working on cars for about 5 years and i am stumped on this problem. My girl friends car will be driving along fine except for a little shutter in the transmission which its had for a long time. recently when driving, periodicly, the engine will rev up to red line and the car will gain a lot of speed on its on, cruise control is off. The only way to keep the engine from redlining is to apply a lot of pressure on the brakes. even when driving and it does this, a lot of brake pressure wont stop the car because it wants to keep going. I have checked and lubed all the linkage for the throttle body and did not find any binding.once this happens, once i shut the car off and come back in a little bit the problem is gone for a week or so till it decides to start accelerating on its own again, Any ideas on what could cause this as the car is unsafe to drive int he winter with this going on. Best regards, Jeff
Oct 29, 2009 at 8:57 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Is this a supercharged engine? Have you checked for codes? foot off throttle it just accelerates? does gas pedal move under your foot? Maybe Idle Speed Control motor
Let me know
Thanks for donate
Oct 29, 2009 at 1:50 PM
JEFFBRIGGS18
  • 6 POSTS
No it is not supercharged. Light has been on for awhile but have not found a place that will check an obd1 for free. tried the hair clip jumping pins but this connector needs the scan tool. We have not noticed the pedal moving at all. what is the Idle Speed Control motor and where is it located and is their a method to test it? Best regards, Jeff
Oct 29, 2009 at 2:04 PM
DOCFIXIT
  • 18,828 POSTS
IAC on throttle body has terminal connector allows air to bypass plate to control idle. it maybe being activated by ECM and rev up engine. If car has 16 pin DLC need scanner
Oct 29, 2009 at 2:18 PM
