1993 Buick Park Avenue trunk
1993 BUICK PARK AVENUE
130,000 MILES • V8 • 2WD • AUTOMATIC
DORITE2005
have a trunk with electric motor to where you ease the lid down so far till it catches and will pull itself closed the rest of the way down. well the motor has quit so trunk stays ajar.can you tell me where or how I could find to take off and operate it manually
Nov 1, 2008 at 10:41 AM
JTMONEY11086
  • 17 POSTS
if u cannot get one from a local junkyard try this,pull the coil out of the side of the motor to where u have a hole i kept turning the metal piece the trunk latches to untill it was low enough for my trunk lid to grab and seal,where u pulled out the copper windings in the motor stick a large bolt in there and turn it untill it is snug. because the metal U shaped thing the lid latches to will turn itself resulting in the lid raisin up by itself over time,snugging that bolt in there will keep the the U shaped metal thing from turning.good luck mine is still keeping the trunk lid down. lemme know if u have any questions good luck
Jun 16, 2009 at 8:28 PM
