1992 Buick Park Avenue obd1 connection
1992 BUICK PARK AVENUE
BULLWALLY
Engine Mechanical problem
1992 Buick Park Avenue 6 cyl Two Wheel Drive
I am trying to trouble shoot a problem in the codes but i notice when i attempt to jump the connector using a paper clip my cooling fan will engage and run. could this be part of my starting problems I repoorted earlier. The car suddenly stops running and when i turn it back on i get plenty of crankand fuel but no spark.
Mar 1, 2009 at 7:34 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Hello, Is your check engine light on? Ground terminals A and B with the ignition "ON" and engine not running. The system will enter the diagnostic mode. In this mode, the computer will display a 12, three consecutive times, by flashing the "CHECK ENGINE", "SERVICE ENGINE SOON" or "MALFUNCTION INDICATOR LAMP" or light. A 12 consists of one flash, a short pause, then two flashes in rapid succession. After 12 is displayed, any stored trouble s will be displayed by flashing the "CHECK ENGINE", "SERVICE ENGINE SOON" or "MALFUNCTION INDICATOR LAMP" light. All s are displayed 3 times each then a 12 will repeat. In the diagnostic mode, the computer will also energize all computer controlled relays and solenoids.
https://www.2carpros.com/forum/automotive_pictures/188069_buickdtcconnection_1.gif
Check out this link for more info on your problem... https://www.2carpros.com/first_things/car_cranks_but_wont_start.htm Also please if you have any other posts with this vehicle please copy and paste them in this one. All you have to do is scroll down toe=ward bottom and click the REPLY TO QUESTIONS. .
Mar 1, 2009 at 7:45 PM
