1991 Buick Park Avenue intermitent heat
1991 BUICK PARK AVENUE
287,000 MILES • 6 CYL • 2WD • AUTOMATIC
MURPH128
I have replaced the thermostat, a bypass hose, put stop leak in system and topped off anti-freeze. The heat comes on intermitinley and the temp guage registers higher than normal.
Am I missing something obvious? there are no visible signs of leakage, and the oil looks pretty good.
Any help would be appriciated
Thanks
Feb 4, 2009 at 10:49 PM
SNAPONADDICT
  • 5 POSTS
there is a air bleeding procedure for the cooling system on that car if you did not do this air could be trapped in the heater core there could be bigger problems i need more info on why you changed the thermostat
Feb 4, 2009 at 11:17 PM
MURPH128
I replaced the T-stat because that seemed like a logical, cheap option. I am an armchair mechanic at best. How does one blled the air from the system?
Thanks for your help
Feb 5, 2009 at 12:32 AM
