1989 Buick Park Avenue Doors
1989 BUICK PARK AVENUE
190,000 MILES • 6 CYL • AWD • AUTOMATIC
Q_MAIN
Every door opens except the front, driver side door. The battery would loose power when car was started for more than 10 min. Now that I connected the wires to the air shocks the cars runs. The only problem is the driver door will not open.
Apr 7, 2010 at 6:46 PM
Have you removed the door panel to check the linkage to the handle?
Apr 8, 2010 at 10:18 AM
Q_MAIN
Thank you.
I appreciate your help.
I removed the inner door panel, but i can not see what the problem is. Can u tell me step by step, the possible problems with the possible solutions?
May 17, 2010 at 11:21 AM
Hi:
Are you able to see into the door handles? Each one, inner and outer, have a steel rod (linkage) that runs from the handles to the latch assembly. Are they attached in both places?
May 18, 2010 at 6:32 AM
