1986 Buick Park Avenue stumble at takoff
1986 BUICK PARK AVENUE
CLOW339
  • 12 POSTS
Engine Performance problem
1986 Buick Park Avenue 6 cyl Two Wheel Drive Automatic 800mil miles
car has new moter in it all parts hav ben replaced ign moduel coil packs wires plugs cool temp sen iat tps mat iac all relays every thing but the camshaft sensor and the crankshaft sensor some thmes i get a coad 42 est the cam and crank sensor some times the car will buck and stumble when i step on gas to take off or from idle it will hesatate then fine stop go to take off its will stumble or stall or no start with light poping then leve it maby ten mins or what ever then run like brand new car some times does this how do i know if its cam or crank sensor
Jul 1, 2010 at 1:51 PM
Check the CMH and CPS resistances and also the wiring back to the computer for open and short
Jul 2, 2010 at 1:40 AM
Camshaft and crankshaft position sensors
Jul 8, 2010 at 1:51 AM
CLOW339
  • 12 POSTS
[quote:0ee3e8badf="rasmataz"]Camshaft and crankshaft position sensors[/quote:0ee3e8badf] im going to change both and ill let you know how it goes im pretty sure that it plus there not anything else to replace i put new moter in it all new everything all sensor and relays fulepump i just never new the emportance of the cps and cam sensor thankyou much
Jul 14, 2010 at 6:06 PM
CLOW339
  • 12 POSTS
i changed both sensor when i was adj sensor crank one of the harmonicbalancer blades is worped it even when it starts to pass through sensor then the next one is almost touching im going to put new balancer on to that should doit i hope ill let you know thank you so much
Jul 24, 2010 at 12:11 PM
