hard start
BUICK
KMH5754
  • 8 POSTS
using a friends 95 regal. having a hard time starting it. cranks but doesnt turn over. other times its starts right up. when it takes a while to start it runs rough for a few minutes. no consistancy with this problem. can be fine for days, then problem all day what should i check?? kathy
Aug 24, 2007 at 6:55 PM
SERVICE WRITER
  • 9,123 POSTS
HEy Kathy,
Intermittant problems are the worst. Essentially you need to do testing when it isn't starting. Your most likely not getting fuel or not getting spark. When it doesn't start you can remove the air duct to the throttle body and spray some carb cleaner in there and then crank it. If it starts, your losing fuel. If it doesn't start, put a spark tester on a plug wire and crank it and se if it flashes or not. If it doesn't flash you may have a problem with the computer that is not allowing spark or fuel to happen.
Aug 24, 2007 at 7:03 PM
