2009 Other Buick Models Buick Enclave problem
2009 BUICK
20,000 MILES • 6 CYL • FWD • AUTOMATIC
PAULETTAGAIL
My Enclave started missing with my cruise on about 9 months ago while returning from a long trip. When I would take the cruise off it would stop. Then it began doing it without the cruise on. Seemed to do more so when going up a slight upward slant on the highway. Took it in to the dealership and was told a spark plug needed to be replaced. It worked fine for about 4 months ...then started to do it again. Took it in again and the spark plug was replaced again. Drove fine for 4 days...then right back to missing again. They say they can not find anything else wrong with it. Any ideas?
Jan 10, 2010 at 3:11 PM
HMAC300
  • 48,601 POSTS
as this is still under warranty it is not really ours to give advice. But i would change the fuel filter and put a good fuel injector cleaner and run that through and see what happens. If you do a lot of shorthops that is very hard on a car engine and it tends to build up carbon/oil deposits.. the fuel may be partially blocked
Jan 31, 2010 at 6:36 PM
