As with a lot of the vehicles lately, you need to remove the front bumper fascia.
Here are the steps: Front Bumper Fascia Replacement and some diagrams (BELOW)
• Remove front compartment sight shield. Refer to Front Compartment Sight Shields Replacement .
• Remove the front retainer from the wheelhouse liner. Refer to Front Wheelhouse Liner Replacement .
• Remove fascia grille. Refer to Fascia Grille Replacement .
• Remove the retainers from the air deflector. Refer to Front Air Deflector Replacement .
1- Front Fascia Bolt (Qty: 2)
Notice: Refer to Fastener Notice in the Preface section.
Tighten
10 N·m (89 lb in)
2- Front Fascia Nuts (Qty: 2)
Tighten
10 N·m (89 lb in)
3- Front Fascia Retainers (Qty: 2)
4- Front Fascia Retainers (Qty: 18)
5- Front Fascia
Tip
• Disconnect the fog lamp electrical connectors.
• Pull out on the fascia to release the tabs on the energy absorber to the impact bar.
• Energy absorber is attached to the front fascia.
Preliminary Procedure
Remove the front bumper fascia. Refer to Front Bumper Fascia Replacement .
1- Headlamp Capsule Assembly Bolts (Qty: 3)
Tip
Tighten the fasteners in sequence as shown.
Tighten
6 N·m (53 lb in)
2- Headlamp Capsule Assembly Nut
Tip
Access the nut by pulling back the front fender liner.
Tighten
6 N·m (53 lb in)
3- Headlamp Capsule Assembly
Tip
•The headlamp is engaged to the sheet metal by a stud located at the lower outboard corner, and 2 pins in the center lower, inside the lamp.
•Pull the lamp outward to release the retainer pins from the body panel.
•Disconnect the electrical harness connector at the lower rear edge of the lamp.
Cheers
Nov 25, 2020 at 8:31 AM
(Merged)
