2007 Buick Lucerne Keyless Entry Programming
2007 BUICK LUCERNE
6,000 MILES • 6 CYL • 2WD • AUTOMATIC
STUBLUE5186
How do you reprogram the entry remote with the car's onboard system? I did it for one of my three remotes, but that changed the other two.,
Jan 16, 2008 at 10:13 PM
DENNYP
  • 1,824 POSTS
Relearn Remote Key
To access this display, the vehicle must be in PARK (P). This display allows you to match Remote Keyless Entry (RKE) transmitters to your vehicle. To match an RKE transmitter to your vehicle, do the following:
Press the vehicle information button until PRESS TO RELEARN REMOTE KEY displays.
Press the set/reset button until REMOTE KEY LEARNING ACTIVE is displayed.
Press and hold the lock and unlock buttons on the first transmitter at the same time for about 15 seconds.
On vehicles with memory recall seats, the first transmitter learned will match driver 1 and the second will match driver 2.
A chime will sound indicating that the transmitter is matched.
To match additional transmitters at this time, repeat Step 3.
Each vehicle can have a maximum of eight transmitters matched to it.
To exit the programming mode, you must cycle the key to OFF.
Jan 17, 2008 at 7:48 PM
