Tail Lights on our Buick Leasbre
BUICK LESABRE
TIM2174
We brought a 2001 Buick Lesabre used, now with 105,00 miles and there was no manual. Can someone please tell me how to replace the blinker bulb on the rear drivers side. I can not figure out how to get to the bulb. Thanks
May 6, 2007 at 2:10 PM
LSUSSEL
  • 252 POSTS
Its very simple, its part of the brake light housing, check the trunk, you may need to pull back the plastice peice on the inside rear of the trunk, like where the trunk lock locks into place, and might need to pull back some of the carpet, but the headlight housing should unscrew from the inside of the trunk and then the housing should pop right out and you can pull the bulb, let me know if this helps
May 10, 2007 at 12:14 AM
