how do I pull the axel to replace the bearing on a 92 buick LaSabre
Aug 19, 2007 at 1:25 PM
MERLIN2021
CERTIFIED EXPERT
Do you want to replace a front wheel bearing? If yes you don't need to pull the axle.Take the rotor off and undo the three bolts, use a 30mm socket for the axle nut and then tap it off with a hammer!
