Re:'94 Buick Lesabre, 3.8l with 150,000 miles.
i have a gas leak in the engine compartment.
all my books say to de-pressurize the system first before repairing by "pulling the fuel pump fuse".
there is no fuel pump fuse in the fuse block IN the car.
there is no fuse specifically labelled fuel pump in the "power centre" under the hood.
there are, however, 6 circuit breakers located under the fuses in the "power centre", but not labelled at all........
is one of these what i need to pull in order to depressurize the system?
if so, which one?
HELP!!!
Thank-you.
if so, which one?
HELP!!!
Thank-you.
May 12, 2007 at 12:38 PM
