2005 Buick Lesabre rear air shocks
2005 BUICK LESABRE
60,000 MILES • 6 CYL • FWD • AUTOMATIC
CWMITCHELL
I replaced the original air shocks with after market air shocks and the car rides very stiff. I put 400 lgs of weight in the trunk and the compressor didn't seem to raise it at all. The compressor worked fine with the old shocks. Can I disconect the air and use them as regular shocks
Nov 29, 2009 at 1:44 AM
DENNYP
  • 1,824 POSTS
They will not function as regular type shocks. Check your air lines for leaks by spraying them with soapy water when the compressor is running. You should also spray the air bladders on the shocks to check for leaks.
Nov 30, 2009 at 9:22 PM
