2004 Buick Lesabre Washer Fluid Won't Flow
2004 BUICK LESABRE
79,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHARI
The washer fluid won't dispense even though I hear the motor working.
It's freezing cold outside, so I just spent better than 45 minutes with the blow dryer on the lines. No luck.
What can I do?
Dec 16, 2008 at 2:35 PM
Hi:
If you remove the supply line from the pump does it spray from there?
Dec 16, 2008 at 9:07 PM
CHARI
Hi Joe,
I took the supply line apart; no it is still not flowing. I still can hear the motor working.
Just in case it was frozen, I left it in heated garage overnight. This morning it was still not working.
I drained the reservoir and put hot water in, drained and refilled with warm washer fluid.
Don’t know what else to do.
Dec 17, 2008 at 8:54 AM
CHARI
Yeah!!! It worked!! Just after I put the warm washer fluid in, it started to work. No leaks!!
So glad I didn't have to start tearing things apart.
Thanks anyway.
Char
Dec 17, 2008 at 9:09 AM
