power window
2002 BUICK LESABRE
76,650 MILES • 6 CYL • 2WD • AUTOMATIC
GIZMO
hello my name is ronnie and i have a 2002 buick lesabre and the window on the right side will not work and the dos work but the window will not go down it try to i think it is off it track and can you tell me if it is hard to fix and can i do it thank you for your time ronnie
Nov 19, 2008 at 1:40 PM
This could be a number of things but we need to start with removing the door panel and operate the window to find out if it is off the track or not.
https://www.2carpros.com/articles/door-panel-removal
If it is, here is a guide that will help with replacing the regulator as that is likely what is needed:
https://www.2carpros.com/articles/how-to-check-and-replace-a-electric-power-window-motor
If it is not off the regulator, then we are going to have to check the switch. This video will show how to test this switch.
https://youtu.be/HBFBcJrdym4
I also attached the wiring diagram below so that you can test the correct wires.
Please run through this info and let us know if you have questions on this. Thanks
Oct 4, 2021 at 5:04 PM
