Fuel pump pressure
2002 BUICK LESABRE
GREENIE5
  • 4 POSTS
What is the correct psi for my car listed above (3.8 liter) fuel pump?
Apr 11, 2009 at 4:29 PM
Here is the fuel pump pressure and how to perform the test as well
Key On Engine Off 53-59 psi
Please run down this guide and report back
Cheers
Apr 11, 2009 at 6:12 PM
GREENIE5
  • 4 POSTS
I have the K engine Thanks for the PSI info. My psi is 43 at idle to 49 at about 2000 rpm, must be my hesitation problem, although when i unhook my MAP sensor car seems to run fine. Heard that low fuel pressure will bring up a MAP sensor code. does that sound logical?
Apr 11, 2009 at 6:38 PM
Yes it does because you are forcing the computer to open the injectors more which will compensate for the weak fuel pump here is guide to help you see what you are in for when doing the job. Your car has a trap door so it is much easier.
Cheers
Apr 11, 2009 at 6:49 PM
TIMOTHY HOLLANDSWORTH
what is the fuel pump pressure for my car?
Jul 22, 2018 at 1:57 PM (Merged)
HMAC300
  • 48,601 POSTS
vin K- 53-59 psi Vin I-48-54 auto parts rent gauge see link. key on only
MAXREICHE
I need to know what is the fuel pressure and vacuum pressure I need to look at it
fuel pressure should be around 40-45 lbs.
idle vacuum should be 18-20 inches
