High oil pressure reading
2001 BUICK LESABRE
130,000 MILES • 6 CYL • FWD • MANUAL
BOACONSTRICKER
The normal oil pressure on my Buick LeSabre has been about 65 psi. About a month ago the pressure reading jumped to 85 psi, then a few days later jumped to 130 psi and has been at that reading ever since. I changed the oil filter, but that had no effect. There are no other symptoms - there is not even a warning light about the high pressure - the display just reads "normal". What could be causing this? Could it be the oil pressure sensor? When the engine is not running and I turn the key to "on" but don't start the engine, the oil pressure reads "0". Once the engine starts, the pressure goes right to 130 psi.
Jan 9, 2008 at 9:10 PM
MASTERTECHTIM
  • 4,750 POSTS
It could be the oil pressure sender or the oil pump pressure relief valve is stuck here is a guide that can help you fix it.
https://www.2carpros.com/articles/high-oil-pressure
Jan 9, 2008 at 9:12 PM
TPH
Electronic gauge all of a sudden shows 300 as oil pressure (but also says"normal"). With engine off shows 0 (zero). I'm going to try an oil change with new filter. What other causes would show this increase in gauge oil pressure. P.s. the car's running fine.
Feb 12, 2019 at 12:57 PM (Merged)
DOCFIXIT
  • 18,828 POSTS
Faulty oil pressure sender
https://www.2carpros.com/forum/automotive_pictures/198357_Graphic_336.jpg
JDFMAX
I have my engine rebuilt 3000 miles ago. At that time my engine oil pressure went down into 0 but the engine oil level was full.
After engine rebuilt, the oil pressure was set at 80 (the original pressure was 40). The mechanic told me they changed a bigger bump and it is better than the old one.
after 3000 miles driving, I found that the oil pressure goes to 85 and some time reach 95!!!
But when i restart the car, the pressure will go back to 85 - 90.
During the 3000 miles driving, i never go faster than 80mph and I always keep my speed at 65 on freeway.
Hi jdfmax, Welcome to 2carpros and TY for the donation
They probably put in a high volume pump in it-if it was me I'll change back to the OEM part oil pump-A typical engine oil pressure while idle should be 10-15psi and at part throttle should range between 30-45 psi -Your pressure is just too high, normally at 70psi the oil pressure relief valve should open-but who knows the pressure relief valve could be sticking/or not opening at all.
JDFMAX
[quote:a039df8311="rasmataz"]Hi jdfmax, Welcome to 2carpros and TY for the donation
They probably put in a high volume pump in it-if it was me I'll change back to the OEM part oil pump-A typical engine oil pressure while idle should be 10-15psi and at part throttle should range between 30-45 psi -Your pressure is just too high, normally at 70psi the oil pressure relief valve should open-but who knows the pressure relief valve could be sticking/or not opening at all.[/quote:a039df8311]
okay. I checked the auto parts.
Melling/Oil Pump Kit
For your 1998 Buick Lesabre 3.8L SFI OHV 6cyl
Is this stuff I need to change for my car??
