I have a 10 amp fuse for the interior lighting that blows, and it has 12vdc across the two pins all the time, others do not. After chcking all the lights I saw on the electrical drawing that the circuit connects at the rear integration module. I unplugged the module and the voltage at the fuse pins went to 0. I had a short in the wiring on that module before which affected other lighting and switches. Is there a way to troubleshoot this module or the short/ground problem? If not do I need a "certified" buick dealer to replace it? (Assuming that the problem is the rim) it looks simple enough to replace but I cannot find it to buy on libe. Do I need to buy this from a GM dealer, if it is the problem?
Jun 24, 2010 at 5:01 PM
