Shakes or Wobbles problem 6 cyl Two Wheel Drive Automatic 161200 miles
Car shakes when accelarating around 40-45 MPH. It shake more violently when driving through a right hand turn under accelaration. Let off the gas and it goes away. The CV axles, hub bearings and tie rod ends were replace on both sides as suggested by mechanic. Problem remained. New mechanic is telling me I have 3 motor mounts that are bad and he thinks that is the problem. I trust this place, but is that a typical problem with this car? FYI...this car had been idling a little high when first cold cranked, so maybe that put too much stress on motor mounts when putting it in reverse. They said it needs a new IEC to fix that. Thanks in advance for your help.
Jan 20, 2009 at 3:31 PM
