2000 Buick Lesabre Cooling fans on radiator
2000 BUICK LESABRE
160,000 MILES • 6 CYL • FWD • AUTOMATIC
RICHADAMS
At what coolant / engine temperature should the radiator cooling fans come on? I have read some where it is about 225 degrees. This seems pretty hot to me. The fans work all the time when the A/C is turned on but I cannot get them to work when the A/C is turned off. Also what fuse / relay controls the fans when the A/C is off, the owners manual does not give this information?
Jan 15, 2010 at 4:27 PM
BLUELIGHTNIN6
  • 16,542 POSTS
225 - 250 Farenheit is the appropriate temp. The cooling fan relay(s) is the relay for the radiator fans. It should be labeled in your relay box.
Jan 15, 2010 at 10:43 PM
