1999 Buick Lesabre P0440
1999 BUICK LESABRE
128,000 MILES • 6 CYL • FWD • AUTOMATIC
KHUBBARD5
My check engine light came on. I just changed my plugs and wires and the light turned off. Now it is on and the scanner gives a reading that says: P0440 EVAP Control System Malfunction. What does this mean?
Nov 29, 2008 at 7:31 PM
A code P0440 could mean one or more of the following has happened:
The gas cap is not installed or working properly
The purge solenoid has failed
The canister is plugged and not working properly
Possible SolutionsWith a P0440 OBD-II trouble code, diagnosis can be tricky at times. Here are some things to try:
Remove and reinstall the gas cap, clear the code, and drive for a day and see if the codes come back.
Inspect the EVAP system for cuts/holes in tubes/hoses
Inspect for damaged or disconnected hoses around the Evap purge solenoid
Check and/or replace the sensor
Check and/or replace the purge valve
Have a professional use a smoke machine to detect leaks
Nov 29, 2008 at 7:51 PM
KHUBBARD5
Thanks for the feedback...I will do the gas cap deal today...but if that doesn't work how do I find all those other things you talked about...
Dec 1, 2008 at 8:41 AM
