1999 Buick Lesabre mass air flow sensor
1999 BUICK LESABRE
23,000 MILES • 6 CYL • FWD • AUTOMATIC
CRAIGFINKE
where is the mass air flow sensor located?
May 18, 2008 at 12:41 PM
CRAIGFINKE
[quote:3881f1ecc1="craigfinke"]Electrical problem
1999 Buick Lesabre 6 cyl Front Wheel Drive Automatic 230,00 miles
where is the mass air flow sensor located?[/quote:3881f1ecc1]
May 18, 2008 at 12:43 PM
BRAVESTAR1
  • 234 POSTS
It is the little black flat box, that is connected to the air cleaner, and probably resembles this. But it's right on the metal housing connected to the side of the engine, to the left of the rubber flexible hose that connects to the air filter box. Sometimes they can be cleaned with a little carb cleaner, usually not.
Tap the screws that hold it down to loosen them, to prevent stripping the heads off.
Jul 24, 2012 at 4:22 AM
