1998 Buick Lesabre Wipers
1998 BUICK LESABRE
ZROSEHEIM
Other Category problem
1998 Buick Lesabre 6 cyl Wheel Drive Type unknown Automatic 200,00 miles
It has been snowing alot this season, and so I have had to use the windshield wipers quite a bit. The other day while driving they simply stopped. I checked the fuses, and they seem to be fine. The washer fluid still sprays as well. I cannot see anything that looks wrong. Do you have any suggestions as to what the problem could be, and if it is something I could fix myself?
Dec 28, 2007 at 1:34 PM
BMRFIXIT
  • 19,053 POSTS
we have done a lot of wiper motors in the past 3 weeks
also what else we did is the links or wiper trannys
so let me ask you can you move the wipers by hand '
if so you can may have a link off
need more info let me know
good luck
Dec 29, 2007 at 12:50 PM
ZROSEHEIM
The wiper blades can be moved by hand, and when I turn them on a whirring noise comes from what I assume to be the wiper motors.
Dec 29, 2007 at 4:27 PM
BMRFIXIT
  • 19,053 POSTS
[quote:f0d96fdbd7="zroseheim"]The wiper blades can be moved by hand, and when I turn them on a whirring noise comes from what I assume to be the wiper motors.[/quote:f0d96fdbd7]
its not the motor
check nut at the base of the wiper arm and also you may have to remove the plastic cover to reach the wiper links (tranny area)
check it may one broke off
Dec 29, 2007 at 7:48 PM
