1998 Buick Lesabre transmission shifts really hard sometime
1998 BUICK LESABRE
124,000 MILES • 6 CYL • FWD • AUTOMATIC
1967NOVSS
I purchased this car about a year ago with 106000 miles on it. I serviced and installed new wires and plugs . I knew nothing of pevious service and was afaid to service transmission at that time. It now has 124000 miles on it. It has started shifting really hard in situations like road trip and transmission downsifts. It shifts real hard then converter locks up really aggressive also. A friend of mine told me there is a selonoid in side cover that may be causing it. Also would you reccommend changing the filter and fluid at this time? It may be 1/2 quart over full but doesn't smell burnt. Any suggestions would be greatly appreciated
Dec 27, 2009 at 2:43 PM
DOCFIXIT
  • 18,828 POSTS
Hi
To find out need trans scanned checking on solenoid operation and pressure tests on line and governor.At 124K if fluid and filter never changed could not hurt allthough fluid may look good it degrades and looses hydraulic properties.
Hope this helps
Thanks for donate
Dec 28, 2009 at 8:58 AM
1967NOVSS
I had ecm scanned it showed tcc stuck on
tcc commanded off by ecm tcc slip detected after off command
problem cause tcc soleniod failure
open or short circuit condition
blocked passage in transmissioncheck transmission range switch for proper operation
unable to give any pressures with their scanner
I am going to change the filter and fluid will let you know how it looks in pan
Thanks for the information Robert
guy at auto zone seems to think there is more than 1 solinoid under vertical pan cover.
Dec 28, 2009 at 2:27 PM
DOCFIXIT
  • 18,828 POSTS
There are a 1-2 shift , 3-4 shift, control solenoid and the TCC see diagram
https://www.2carpros.com/forum/automotive_pictures/198357_Graphic_284.jpg
Dec 28, 2009 at 2:39 PM
1967NOVSS
can you tell me what transmission this has in it to assure proper ttc solenoid thanks Robert
Dec 29, 2009 at 1:28 PM
DOCFIXIT
  • 18,828 POSTS
4T65-E
Dec 29, 2009 at 1:49 PM
