How to replace the serpentine belt?
1998 BUICK LESABRE
SONNY78
Other Category problem
1998 Buick Lesabre Engine Size unknown, Automatic 67,000 miles.
How would I replace my serpentine belt on my car listed above?
Jan 27, 2008 at 4:44 PM
BMRFIXIT
  • 19,053 POSTS
pull the tensioner away from the belt remove the belt
https://www.2carpros.com/forum/automotive_pictures/99387_38buick__belt_1.jpg
https://www.2carpros.com/forum/automotive_pictures/99387_38belt_1.jpg
Jan 27, 2008 at 8:09 PM
ALPHAA10
  • 232 POSTS
Does 2CarPros have a video showing how to pry the tensioner pulley away from the belt? The key view of the process is exactly what object the pry bar pries against. If the pry bar pries against a bolt, or even the tensioner pulley itself, the view should show that clearly.
Oct 13, 2021 at 5:48 PM
SQM
  • 6,383 POSTS
Are you trying to replace the belt?
If so, to take the belt off you need to put a 15mm socket on a ratchet (or barker bar). Put the socket on the bolt of the tensioner pulley and pull it counterclockwise (you are not prying against anything).
Check out this helpful video:
https://youtu.be/sCfHg7bI2pw
Let me know of any questions.
Thank you.
Oct 13, 2021 at 8:31 PM
ALPHAA10
  • 232 POSTS
Thanks, that helped. though the narrator/demonstrator had his shoulder blocking the camera view, just at the moment when he counterclockwise rotated the tension pulley bolt. This is a fairly clear demonstration, however.
My expectation of having to pry the belt tensioner loose came from experience with another vehicle.
Oct 14, 2021 at 4:12 PM
SQM
  • 6,383 POSTS
Got it. It is quite simple on this vehicle.
Let me know if you have any questions.
Oct 14, 2021 at 6:40 PM
